DCaccamise
I purchased a '95 4X4 with a bad transmission. It wouldn't shift into second gear and eventually, reverse went out as I moved it around the parking lot after it came home off the tow truck. It did leak a lot of fluid too. Generally said, the E4OD transmission needed a rebuild.
I'm an aviation mechanic, so I'm good with my mechanical skills, however, I never rebuilt an automotive transmission before. I was a bit leery about it, but I took the job on to save the $$.
After disassembling the transmission in an organized fashion by grouping the sections together, I just rebuilt everything one section at a time and was in no rush. All the plates and clutches in it were pretty much toast, so I knew that it was obvious what the problem was, besides bad seals which caused the original leaking also.
I purchased a good quality rebuild kit and a deluxe shift kit to do this repair. Also, the neutral safety switch sensor got cracked when the transmission was removed, so I simply replaced it with a junk yard replacement.
Now for the problem: I completed the newly rebuilt install and started up the Bronco. The results are Nothing!
Is it possible if I put a sprag bearing in backwards that this would cause this locking up situation?
I didn't read that I had to pre-fill the torque converter. Could it be locked up?
Help
- 1
- 2
Help
