You're right, no cam break in required. For first few miles(100-500) or so try not to hold a steady speed for long periods..like highway running.. After initial start up, putt around a little and make sure no leaks, over heating etc... then take to a road where you can take off from a stop and go through the gears a few times...then run each gear up then let off abruptly, this causes back pressure on the rings and causes them so seat.. You will probably get several opinions on this, some day drive it like a granny for about 500 miles, then drive it moderately for 2000 before doing anything extreme.. And others like myself feel you should drive it like you stole it from the get go, if it was built right it can handle it... and I would want to know if there is a problem right away.. ;D. With that said, I do take it easy for the most part, I do however stick my foot in a new engine a few times to make sure it is ok... BUT do not over rev it...that will cause problems in any engine.. OH, and run a rev limiter if possibel..LOL!! I know for a fact, my hand will shift it into neutral before my foot can come off the gas...allowing it to hit the rev limiter..
