Recommended distributor for EFI
JWMcCrary
Switched over to Holley Terminator EFI about 2 years ago but kept my old MSD distributor setup with the ignition box. The way its setup now the EFI doesn't control the timing. I want to change the distributor and let the EFI computer control timing. What distributor do I need? My understanding is Ford TFI, they range in price from approx. $175 to almost $400 at Summit. Just want to make sure I get what I need. Going on a 351W stroker with aluminum heads, etc.
Bronco_69
Monette Ar
the timing in the ford efi is controlled at the ecm. you need whatever works with your holley efi system.
i like the used OEM ford distributors over any other. with a 351w you will have to get one for the taller deck height. the gear also needs to match your cam
broncopilot67
Port Orchard
Hi Im going through the same thing with the Holley terminator . I have a 302 flat tappet cam. I have done a lot of reading and have decided to go with a Performance Distributor. Just got it in the mail yesterday. I will update you on how it goes this weekend. One problem i might have is that the shaft might be about .5 inches to long for the oil pump as this Distributor is for a roller cam. But as i under stand there are two different oil pumps the later model ones will take the longer shaft. Only thing i have done is change the gear for a flat tappet cam. On the Holley help site they say any TFI will work.
JWMcCrary
JWMcCrary
They give a lot of detail for using the system GM HEI, but the information for Ford TFI is not very detailed, maybe it doesn't need to be, but I know nothing about it. I will be curious to hear how it works out for you. After doing more reading I'm leaning towards leaving mine as is.
Nickm1024cobra
Chicago Burbs
I don't know what distributor you can use with that efi but I do know Ford TFI. I ran a $400 mallory TFI for a 351 about 1,000 miles before it burnt up (I'll sell it cheap, think it needs a pip sensor :)). Replaced with I think a 95 f250 duralast. Made 425+ hp on the dyno with that factory distributor. The new MSD and Mallory are junk in my book.
JWMcCrary
JWMcCrary
I left it as is. The EFI doesn't control the timing
JWMcCrary
JWMcCrary
Mainly because I'm old school. Going from carb to EFI was a big leap for me, I'm sure I will eventually do the swap but have other things ahead of it for now. It will just add one more thing to the mix that I have to learn how to troubleshoot and work on.
SSDDBRONCO
Los Angeles
Ok makes complete sense. Thanks
JWMcCrary
JWMcCrary
Well, now all your threads have me thinking about this again. lol
SSDDBRONCO
Los Angeles
Hahaha. Since I have to use a cast iron gear, non of the reman-ed distributors have cast irons, they only come in steel and for some reason it specifies that the gears aren't interchangeable?? Have no idea why. So I'm either going to buy a Richporter or Duralast Gold, with a remote mounted TFI, as a big problem to the failure of the TFI is due to excessive heat so that may solve a lot of isssues.
JWMcCrary
JWMcCrary
I thought you could change the gear on the distributor?
SSDDBRONCO
Los Angeles
Ya that's what I thought as well. Maybe they state that in the description as it will void the warranty? I'm going to talk to the guys at the auto parts store and see what they say about that.
