Removing front drums
Vintage Steel
Post Falls, ID
Got a 69 with the Dana 33 front end and drums
Cant get the front drum off, I don't have a book.
Do I need to disassemble the hub?
bigger hammer?
thanks, Russ
Skiddy
D30 yes you need to disassemble the hubs, may want to get a book so you know exactly how the hubs come apart
Pipehitter
Clintonville WI
You need to back off of the brake shoe adjuster all the way from the back of the drum, then if the drum does not come off, adding heat to the drum will help. I have a 1975 I bought from the original owner and after heating the drums to almost red hot, I was able to remove them. Needless to say, I went and purchased new drums. Good luck
bax
Old Member
Studs are a press fit thru the hub and the drum. Take it all off. When I put mine back together I opened up the stud holes on the drum just a tad so now I can take the drum off without removing the hub.
