mtrEb
I lost my key to my ignition and was wondering if anyone had any ideas on how I should remove the ignition without it???
Jeepster said:
If I remember correctly you have to rotate the key back to the acc. position and then there is a very small hole in the face of the tumbler that you have to push in, then the whole tumbler will slide out.Jess Luvs 2Romp said:how do you take it out with the key? mine is still sitting in my unattached dash.
mtrEb said:I lost my key to my ignition and was wondering if anyone had any ideas on how I should remove the ignition without it???
mtrEb said:I'd really like to save the switch I got and just get a key cut for it.
hotwheels did you break the cover to get it off?
walker949 said:Oh Man BAD karma with this one. You have 3 options because of the way the switch is made.
1. Get the drill. You will have to get a new switch assembly. By the way if you go this route the door locks will have to be done at the same time.
2. The screwdriver method. this is the 50/50 method of salvage. Get a screwdriver that JUST fits in the switch. Twist the cylinder of the switch counterclockwise until the cylinder comes out. If your very lucky the cylinder comes out with little or no damage and you can reuse it but you need to get a key cut for the cylinder and get and install a new ignition switch because this method really buggers the switch.
3. The door lock method. Most Broncos, the door lock and the ignition switch is the same key. Take one of your doors apart ( I did the passenger door) and take out the door lock. Take the assembly to a locksmith and have him make a key for the lock. Usually fairly inexpensive because you brought the lock in instead of them coming out and working on it in a vehicle. Tell them you are not in a hurry and give them a reasonable amount of time to do it. After they return the lock with the new key, try it in your ignition. If it works, start the Bronco, drive to the nearest hardware store and have 3 spares made. Now you will never have to worry about this problem again because you will always have a key somewhere. If it does not work, a PO changed the locks on the door or ignition and you are hooped.
The door method saves the switch but it is an expensive bet that the locks match
TOFIC
rjlougee said:If you tried to order a set of three matched lock sets, they were about $60 last I looked...
