Replacement Explorer cam
Boss Hugg
IF a guy wanted a little more umph from his explorer 5.0 Efi operated bronco device, what cam would be a good choose? Has anyone degree’d the stock cam? How much lift did it have? I’ll be researching it tonight, but thought I’d ask here in case anyone knew right off.
Timmy390
Conway, AR
Stock cam specs
Explorer F4TE-6250-BA Hydraulic Roller
Intake at 1.6 rocker ratio .422" lift 256 duration
Exhaust at 1.6 rocker ratio .448" lift 266 duration
1.7 rockers is .449 intake and .476 Exhaust
116 lobe separation
Same cam in the Explore and the trucks/vans with 351W's
If you have GT40P heads you will have to change springs for ANY cam bigger than stock. Stock springs are just big enough to handle the stock cam.
NoCal guys like the "stump puller" which I don't recall the part number off the top of my head.
I went with this for my 351w. I could tell a difference....I like it but my SN95 EFI doesn't like with the Stock cam tune.......but I'm working with it.
Comp 35-349-8/XE264HR
Advertised Duration (Int/Exh): 264/270
Duration @ .050 (Int/Exh): 212/218
Gross Valve Lift (Int/Exh): .512/.512
LSA/ICL:114/110
RPM Range: 1,500-5,500
Tim
surfer-b
Boss Hugg
Boss Hugg
This thread shows a desktop dyno comparing an Explorer cam retarded 8 degrees and an HO cam advanced 4 degrees.
Interesting comparison.
http://classicbroncos.com/forums/showthread.php?t=252688
Interesting chart, but my biggest complaint is off idle, which is probably because of huge throttle body the explorer had. Of course, I could use a little more up around 27-2800 where I run 70-75. (5.13 gears)
Boss Hugg
Boss Hugg
What kind of machining is necessary for the XE258HR K kit? It doesn't include new valves, so?? Maybe threading for studs? Maybe PTV interference?
Boss Hugg
Boss Hugg
everything says to replace the GT40 stock valve springs over a certain lift, so I wanted to throw that out there to factor in.
I like to read this: http://www.norcalbroncos.com/forum/showthread.php?1152-What-cam-for-5-0
I read that last night. I really like what I'm hearing about the XE258, but cost is the problem now, especially considering the heads have to be machined. I'm guessing now that the new springs are longer, which requires the pockets to be milled a little deeper? Maybe I can do this with a deburring tool?? ;D;D%)
Really didn't want to pull the heads either.
Looks like I'm gonna drop this idea, at least until I hit the Megamillions tonight, which reminds me I need to buy some tix...
gambling209
Look on the internet at a place called Alex parts. They have drop in Spring kits no Machining required big enough to run any cam you want. Got a set all quality stuff priced very well
Timmy390
Conway, AR
Bought my springs from Alex Parts when I upgraded. You DO have to make sure to get the spring height correct which also means spring pressures. Shims might be needed to get things right.
I took my heads to a machine shop along with the spring kit.
Tim
Boss Hugg
Boss Hugg
Guess I need to study up on setting spring heights and pressures?? I like doing everything myself which saves on paying someone else to do it. At the end of the day, I feel accomplished. And I don't take the risk until I'm VERY sure it's going to work.
Thanks for the tip on Alex!
Boss Hugg
Boss Hugg
And the next question, are the stock lifters good enough to match the XE258? And will it require different pushrod length?
gambling209
Alex sells shim kit specific for each spring kit that he sells. Took mine to a machine shop to set up. They said it was spot-on with provided shim kit. Roller lifters are roller lifters no problem there. Always check pushrod length.
Timmy390
Conway, AR
Mine were spot on as well BUT my heads had not been worked on. They were a direct pull off at the junk yard (long story). I didn't have the tools to do the checking and didn't wnat to chance it (had already had a few head issues with my 351W build) so Machine shop it was......
I reused my roller lifters.
X2 always check pushrod length. I got my checker from Alex Parts.
Tm
gambling209
You can make a pushrod Checker. Get an old push rod cut it in half , put a screw in it lengthen it and shorten then measure it
