Replacing fire wall/Heater removal question
buckin bronco
I want to install a fire wall. I know I have to remove the heater and I would like to do a little metal work too. I know as things go I won't get done in one session. I never do. What do I do with the hoses that run to the heater so I can drive the truck until it's all fixed. Do I just cap them at the radiator?
Also and probably more importantly, do I have to remove the dash to install a firewall?
Thanks.
Victor
ogr
Vail
Take a short piece of heater hose and loop from engine manifold fitting to water pump fitting.
madness
how much of the firewall are you talking about? if its the entire peice, you will need to pull pretty much everything including the collumn, if its a section, you may be able to get away with jus pulling whatever is directly around it. Remember though, the more stuff is outta the way, the better and easier access you will have for cutting/welding/seam sealing etc to make sure its done right.
