RetroSound For Bronco
EricLar80
Anyone seen or used one of these before?
RetroSound Huntington Ford Bronco Radio
https://www.retromanufacturing.com/pages/retrosound-sup-sup-huntington-ford-bronco-ford-truck-radio
68stang73
My local stereo shop says they sound good but if you want anything with boom then get some amps to go with it.
luke
I have installed one in my 73 restoration, but not powered it up yet. Looks great though. Very deceiving.
Mtgrizzlymn
I have one looks great but I can't find anything to give me decent reception. I don't have exterior antenna
Sent from my iPad using Tapatalk
Lunar-tic
Brentsville
I have one, plenty powerful for what it is. I used one of the hidden antennas from one of the vendors. Reception is pretty good, but I like the blue tooth, aux, and USB ports too.
trekgurl
I did the retro sound stereo
I had a guy install my stereo system and he asked me what I wanted. I said marine grade stuff and I want to be able to hear it at 65 miles hour with the top off :eek:. I never thought he could do it, but it will make your ear drums flutter (I have to turn it down) and you cannot hear the engine (headers and short pipes w/ turn downs) too.
(2) small 4 inch speakers in the dash, then the box behind the seat,(it's thick 3/4 plywood wood bolted down) 650 watt amp, 10" sub pointing down (in the center) and the (2) 8" speakers on each end. All marine grade stuff. Looks rather dull but just right for me. Not really for the family type set ups (bench seats) as mine is a two seater.
The retro sound,, It looks plain and simple (I like the original OEM look) but it's got a lot of features and I don't go anywhere without the book as it takes me while to figure out how to get the settings right. I not a stereo expert, (far from it) but it does seem to have a lot of adjustments for treble, mid range, base, sub, MHz and on and on. Different settings for type of music. classis , rock, etc. I just get it where it sounds good and then plug in thumb drive (80-100 songs) and I'm at the beach in about 50 -60 songs. Me and ole Bocephus. :cool:
Does well on regular stock antenna and AM FM radio but I mainly use the USB feature, which gives me lots of tunes using a thumb drive. I've not used the blue tooth, as I don't even have a smart phone. I have been thinking about a satellite radio unit and plug into the AUX. I don't see any reason wouldn't work great as the system has the power and speakers.
I got about $1300 in mine (that's everything). I would think you can get by with a less expensive system, but with my past experience with bronco's , stereo's and the noise,, get the most volume you can,,, then just turn it down.
DaveLev
I have been told over and over by the Mustang, Belair, Corvette, and hot rod communities I'm in to consider other options. I am told that off-the-shelf/out of the box they've had problems with these systems. I recommend a radio delete dash, or put a stock one in and find an alternative if you want no cuts in dash, otherwise, mount to bottom, in glove box, in console, overhead, or hide it via bluetooth/marine option. My 2 cents.
DaveLev
I think the Kenwood marine ones are better...this appears to be a bit esoteric for my tastes, and like something off-the-shelf with a warrantee is a better route, IMHO, and many people here seem to like them.
68stang73
I just installed two systems in my rigs alpine and Kenwood and both on Bluetooth sux!!!!! No bass at all, yes it plays but the sound quality is not great. USB pounds hard and cd is the best by far.
jdeignan
I've got it installed on my 74. Install was super easy. Running a single speaker in the dash stock location. It isnt amped, and once you hit the highway its pretty useless- but it was simple and plenty of sound if youre just looking to cruise around town.
englewoodcowboy
Lick Creek Restorations
I have it in my bronco and am mostly pleased with it. The FM reception is weak as others have mentioned and I am using a stock type antenna. Which needs to be extended about 36" for it to receive OK. I mostly use the Bluetooth anyways so not a big deal for me. Now what I love about it is that you can remote mount the head unit, this is a big plus for anyone who is modifying their dash, limited real-estate as is and with it being remote mounted saves a few precious square inches. As far as power is concerned, I am running a 1200w clarion 5 Chanel amp and it sounds great. Lots of volume control and between using the stereo built in crossovers and the amp crossovers you have plenty of tune ability to make it decent.
Sent from my iPad using Tapatalk\
BroncoChick2
Thinking of giving this as a Christmas gift... any suggestions for a speaker? This will be used w Bluetooth only, no interest in an antenna, etc. thanks!
904Bronco
San Martin, CA
I have one installed in my 71, with their amp. Once I resolved the reception issues, which was a defective Scott Drake antenna, it works great. I use the USB port a lot for my ipod. I have 6x9's in the back and 4" in the doors. The company is based in Henderson NV and their Tech service was great to use.
Woodm
Lutz
I installed one in and it works. All the modern conveniences with the old original looks.
Crawdad
Guys I’m on the ropes, can you post some pics of your retro install in stock location?
tirewater
San Francisco Bay Area
I'm not terribly thrilled with the Retrosound radio. I would've been fine just getting an original AM radio. Yes, I'm nit picky, but the radio was expensive.
I can't figure out how to keep the thing from turning on when the vehicle starts. Even if I shut the radio off before hand. It should remember the last on/off state when I start the vehicle.
The radio works for a few minutes, then distorts and goes to static. I'll try powering it directly from the battery to see if this rectifies the problem.
Bluetooth is fine.
It would be nice if the wire harness was modular and plugged into the back of the unit. There are a lot of wires coming out of the back of it that need to be tied up and out of the way.
The front face plate didn't come with the deep well nuts that they show in the installation picture. I asked them and they said they'd be more than happy to sell them for me for $10. If you want the knobs closer to the face plate you'll need the nuts.
