RetroSound For Bronco
twood9mm
so cal
Huntington retrosound install isuues
Anyone seen or used one of these before?
RetroSound Huntington Ford Bronco Radio
https://www.retromanufacturing.com/pages/retrosound-sup-sup-huntington-ford-bronco-ford-truck-radio
I got the Huntington Retrosound for xmas but I cant figure out how to install. Stock 69 dash. There's no way it will fit in the dash and up to the original radio location due to the ducts for defrost. Even if I remove the duct, the radio is simply too big (as small as it is) to force up. If I cut my front opening to allow installation straight in from the front, it appears that the ducts would still be in the way. Cant lose the defrost. My opening is 1 7/8 tall and the retro is 2 in tall. Also the stock dash holes for the shafts are spaced 5 1/4 while the retro faceplate is spaced at 5 3/4. Vendors that say this is a direct fit are wrong. Any suggestions?
T4x4R
Just did mine today, havent powered it up, but the kit was very complete and pretty intuitive. I just like the look as well.
pipeline010
if either of you guys wanna let go of your stock AM radio hit me up with a PM. It doesn't need to work, either. I just want the stock look but have other plans for music.
I posted up in your other thread too twood, but thought I'd add some more here. Maybe Englewood will see this and elaborate on his remote installation comments. That sounds like an option for some anyway.
Not sure if you've got an alternate mounting spot in your Bronco though. My DIN radio is in the center console, but I'd love to have a Retrosound mounted in the dash.
My issue is that the aftermarket A/C unit is just way too much in the way. The original setup had more room. Doug tried the stock radio and it would not work, but I have not compared the size to the Retrosound directly yet.
Is it possible you have an aftermarket heater installed?
The ones I've seen are all pretty awkwardly fitted there. Though one would think that they're designed to fit with the original radio, so would fit with the smaller Retrosound version.
357Bronco
New Hampsha
I've installed a couple in my shop for customers, the last one being a '68 Bronco with a soft top. You really need an amp of some kind like most stereos anyway. I ran 4" door speakers powered from the head unit and Retro Sounds powered sub under the rear seat, actually mounted to the rear seat facing down, totally hidden and out of the way . Sounds great and still can add more speakers if necessary. Also with the Sub it has the remote bass control, which is nice to fine tune with, and that was also hidden inside the Tuffy Box. I'll be installing Retro Sound stuff in my own vehicles.
