return line for 4x4x2 box
jmangi62
Does anyone know what size fitting goes on the return side of the 4x4x2 box?and where I can get it? I already have the fitting on the supply side,just need the return side,thanks guys,Jim :cool:
Pa PITT
Stephenville TEXAS
One side of my box was nothing more than a Hyd line fitting . Not std for P/S boxes but if the shoe fits wear it. Other end of my
Last one I worked on we just used a short piece of pre-fabbed 3/8" steel line like you get at any auto parts store. The type with the pre-flared ends and threaded fittings on both sides. Cut one end off to the length that was needed and used that.
Actually had it bent into a 90 by Royal Brass here locally because they could get it tighter then I could with a hand-bender.
Threaded it in to the box, clamped on some standard rubber fuel/oil rated hose and away we go.
I would imagine that there is the possibility that different sized holes exist depending on what gear box input section was used to convert the box to reverse steer, but don't know that for a fact. Just that Ford might have changed specifications over the years, so worth a confirmation.
jmangi62
jmangi62
So are you guys saying that they're both the same size? And can I get it at the local NAPA,ORiellys etc.?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The pressure and return lines are not the same size. The return line on a 4x4x2 is the same as a stock EB box, but the pressure line is different. You can get a return line fitting and starter tube for about five dollars at any autopart store. Then buy the PS return line by the foot to hook up.
jmangi62
jmangi62
Thanks guys,this is the final part to my power steering buildup,next is TRO conversion,thanks again,Jim :cool:
