Anybody used hype horsepower sales llc front disk conversion kit?
THIS FRONT DISC BRAKE KIT works great on any Bronco, 66-75. It is ready to bolt on, and easier and cheaper to do than some other kits which involves changing your knuckles, ball joints and tie rods. Your Bronco's stock front wheel bearings & spindle nuts will work with this kit. It is recommended that you install WARN HUBS with this Kit. ALSO, you can install this Disc Kit on a dana 30, and if you up-grade to a dana 44 you can transfer it over!
THIS DISC KIT INCLUDES: Easy to follow INSTRUCTION Guide, 2 brand new machined & balanced HUB&ROTORS with 5x5.5 stock bolt pattern and new races, and 2 new CALIPERS, and 2 new Full Shield CALIPER MOUNTING BRACKETS, 2 new SPINDLES, and a new set of Premium semi-metallic Disc Brake PADS, and 2 new plastic coated Stainless Steel Braided CALIPER HOSES (D.O.T. certified), and 4 new caliper GUIDE PINS, 2 new BANJO BOLTS w/crush washers, 12 new Spindle MOUNTING BOLTS (grade 8) and Lock Washers, assorted hardware & new seals
OPTIONS for this DISC BRAKE CONVERSION KIT:
WARN PREMIUM HUBS $99.00 with no extra shipping fee.
TIMKEN BEARING SET $49.00 with no extra shipping fee.
Will total about $800 with shipping
Opinions? I'm not a master mechanic.
