Hey,
I'm not sure if I should be considering this option; but, I am thinking about modifying the rear wheel wells of our '71 Bronco to allow for the installation of a propane tank. This is just one of several options, although it's going to be the least expensive before the work on the wheel wells is considered.
I know that the question of clearance of the tires in the wheel wells depend on a lot of factors. Without flexing the rear axle and tucking a tire, it looks like there is about 3" between the inside of each tire and each inner wheel well. Although it isn't precise at the moment, I am thinking that is about the same amount of distance required to fit the tank ahead of the wheel well. The tank will be located between the front seats and the rear wheel wells. It is 20" diameter and about 46" wide at its furthest point. (Only about 10" of the front of each wheel well will require work to narrow it.)
Does anyone here have experience narrowing their wheel wells? Should I even be considering it?
(This really isn't a good option to me; but, I thought I would explore it.)
Thanks for any input you'd like to provide.
Jeff
Jeff
