Right Front Turn Signal
brbuilder
My RF tun signal is not working. RR and left side turn signals work as do all of the em flashers including the RF. Where does the wiring split for the RF and RR turn signals? This is on a ‘69 if that matters.
The wire to the RF turn signal is white with a blue stripe. The 2 wires coming from my steering column for the turn signals are green with an orange stripe for the left turn signal. Changes to yellow with a black stripe at a 2-pin connector. The other wire for the right turn signal is orange with a purple stripe and changes to light green at the 2-pin connector. I can’t find where it changes to a white with blue stripe wire.
My fuse box is located just above and to the right of the gas pedal. This is also where most of the wires penetrate the firewall to the engine area.
The wiring for the front and rear signals splits in the turn signal switch. It has to in order to isolate the brake lights from the front turn signals but still have rear turn signals combined with brake lights.
What the switch really does is disconnect the rear light from the brake circuit and attach it to the turn circuit, at the same time it brings the front signal and attaches that to the same circuit.
The dash indicators are attached to only the front turn signal wire, this keeps the dash indicators from coming on when the brakes are applied.
Since there is only one turn flasher (not to be mixed up with a hazard flasher) the turn signal switch decides if the left or right signals should be attached. Or neither and the brakes are left for both rears.
brbuilder
brbuilder
Thanks.
Guess I need to check the other 6-pin connector more closely but it’s sounding like the problem may be in the turn signal switch itself.
brbuilder
brbuilder
Installed a new TS switch from Wild Horses and that fixed the issue. Thanks Broncobowsher.
