What I mean is that on the RIGHT REAR WHEEL CYLINDER, one of the pistons (there are 2) is stuck in, so the other one is pushing out twice as fast... this causes one shoe to be pushed into the drum before it is supposed to, leading to a lockup of this tire.
When the brake pedal is pushed, a piston is pushed down the master cylinder, forcing the brake fluid out, through the brake lines, and into the slave cylinders/calipers. This hydraulic pressure then pushes the pistons out, which forces the brake shoes/pads against the drums/rotors. All of these items are designed to be balanced: the master cylinder diameter and throw must be properly sized for the calipers and slave cylinders so that the proper amount of fluid is forced into each corner, providing equal forces upon all braking surfaces. If one piston is stuck in a 2 piston component (like one side of a rear wheel cylinder), the other piston is forced out twice as far for a given stroke of the master cylinder. This excessive movement will cause the offending piston to force its pad/shoe against the drum/rotor early.
You should be able to determine if I'm right if you remove the right rear drum and have someone step on the brake. I'd put money on either one piston sticking, or something preventing one side from moving properly.
Good luck
G'dood
