No.
You need 3 1/2", or a maximum 3 3/4" backspacing to fit proper. Anything more and it creates all kinds of problems, and specifically on a 77' model.
17" wheel diameter work great, and do fix a lot of clearance issues.
Without getting into a big and complicated explanation, the wheels that work best are 17" diameter, 8" to 9" wide, with 3 1/2" of back spacing. These wheels fit nicely with 33" to 37" tires with 12 1/2" width rubber used on a 76/77 model
EDIT: The OP used the term offset, and in my comments I used the term backspacing. These two terms mean different things, and sometimes are *wrongly* interchanged to add confusion. Here's a neat little diagram
http://www.4wheelparts.com/tire-wheel-package-guide/wheel-offset-backspacing.aspx
