My original reverse lights don't work and don't want to chase down the problem since I want a brighter light. Have been looking at normal led flood lights to mount on my frame but they are rather big and don't have a lot of "wiggle room" on how you can mount them. So had the idea of getting a set of rock lights (hopefuly 6, 1 in each fenderwell and 2 or reverse lights) but didn't know if they put off enough light to be used as BRIGHT reverse lights. During the summer I had the cab off and used my brake lights as a guide, but now since the cab is on and tint is on the windows, I cant see nothing.
Ive seen a few older threads that use lights from wallyworld, are they bright enough for what I want??..Any ideas on a set of small led flood lights that can be mounted from there side and not the bottom??
Also what kind of wattage should I be looking for...I want the brightest light but not drain my battery with an hour of sitting without running...if that is possible
