Rock Skis Recommendation
Underton
Reno
I recently slammed a rock into my rocker panels and put a pretty good sized dent into the side. I've decided that it's time to upgrade them to something a little bit stronger and I was looking at a pair that Wild Horses sales. http://www.wildhorses4x4.com/product/Rock_Rails_Skis_Steel_Customizable_Rocker_Panel_Protection
I was wondering if anyone has every purchased these before? I've also seen people just weld some square tubing right there which I could imagine would be a little bit cheaper, but probably doesn't look as good.
I ran BCs for years on AZ rocks. The ¼" is very solid. I have lifted a side with a hi-lift directly on the BC slider and then drove off the jack. Couldn't hurt it.
I will also attest to they have the stock Bronco body shape to them. Looks much better then the home brew box tubing. The wild horse version looks like the BC version, but not having seen it in person I can't vouch for it.
garberz
Bronco Influencer
Conejo Valley, Ca.
I used 2x5" tubing. You gain a few more inches of ground clearance this way. You'll have to ditch your aux. fuel tank, because cutting the rockers leaves it exposed. It certainly is cheaper to build this type yourself. I think the higher ground clearance, low profile tubing looks fine, plus the tubing offers a bit more protection because it sticks out an inch from the body. They're great for pivoting around rocks.
Mark
OKLA70
Skiatook, Ok
I ran the 1/4" thick ski's from one the the vendors and they work great...BUT, after a summer of actually using them, the body pushed inward instead of denting. I didn't notice it til I put the doors back on. A brace between the frame and ski would solve that issue.
Tim
SteveL
Huge chevy guy
Hawthorne ca
I was gonna build some out of 2x6 but was too easy to by bc"s and bolt em on. Had an idiot in a lowered honda slam into the side of my 72. I couldnt even tell where he hit. The honda was jacked up
jkskier
Western Washington
Locofomoco rock skis, quarter inch thick, plug welded under the door sill and a couple arms to the frame. They're rounded to blend in like the factory rocker. Can't hardly tell they're there, can ya?
(4.25 inches of gained clearance)
