I will say sorry right up front, but this might get a little long. My valve train has been getting louder over the past 6 months. I thought it was a couple of bad lifters. I stsarted yesterday taking things apart. Once I got the valve covers off, I noticed several of the rocker arms were very loose. I got excited, now I don't have to worry about the lifters if the rockers are the source of the noise.
So, I followed the Haynes book and tightened all rocker arm nuts to 17-23 ft. pounds. I hand to turn all of them a lot to get 17 ft. lbs. I put the covers back on thinking this was the fix and tried to fire the motor. The motor turned over with no resistance. I now had no compression. Now I am getting frusturated.
I then took the valve covers back off and backed off the nuts untill I could move the rocked slightly. She fired back up no problem. Now I had all the rockes making noise. I thought I will just tighten them up to 10ft. lbs. while the engine is running. This made the engine not want to idle and even pop back through the carb. I got pissed at this point and called it a night.
Talking to some buddies, I have decided to back off the rocker nuts one at a time untill they start to "click" and then tighen them one full turn the point of no noise. Will this work.
One more thing everyone should now. I have no idea what cam and push-rods are in this engine. I was "professionally rebuilt" shortly before I got it.
Thanks in advance, and sorry for the long post.
Rodd
Rodd
