Torquing rocker arm nuts?
Vin-Man
Milford, Illinois
My brother has rebuilt the 302 in his 1970, and the rocker arm nuts seem to keep backing loose on their own. If I'm reading Chiltons correctly it's saying torque to 18-20ft. lbs.
Is that correct?
He was told by another bronco owner he had never torqued a rocker arm nut, that he should just tighten them down till they stop.
Could someone tell me the correct method?
broncnaz
chiltons is correct. They are probably backing off because the self locking portion of the nuts is worn out. Get new nuts.
bmc69
From '68 onward, the rockers are not the adjustable type (they are called 'positive-stop' type instead) and, yes, you torque them down tight as you noted.
Vin-Man
Vin-Man
Milford, Illinois
He got new nuts but he said they didn't feel any different going on than the old ones (that makes me chuckle a little), He said they didn't screw down any harder than the old ones. Should you be able feel a difference when hand tightening them? or will it not make a difference till their torqued?
Skiddy
Yep that happend to me on a chebby once right after I rebuilt the motor and kept breaking rocker arms. Note: do not use an impact on them%)
wildbill
Old Bronco Guy
;D ;D ;D The stud's are just pressed in make sure they arnt just pulling out a little. Have seen this happen meney times on a motor with a over stock cam. Good luck.:D :D :D Bill :D :p %)
Vin-Man
Vin-Man
Milford, Illinois
He called me back this morning and says he believes the valve face and seats were ground, but that the valve stems were not ground.
Could this make the stems to long when torqued, and would that keep the valve from seating when the lifters are pumped up?
braxton357
morganton NC
Where did he get the nuts? You shouldn't be able to hand tighten them...
Anyway, I'm cheap...so on my old 351 I just torqued them then double nutted them and it worked fine.
Vin-Man
Vin-Man
Milford, Illinois
I'm not sure where he got the nuts. I would assume Napa, it's the local parts store, but i really don't know. I wondered about double nutting too.
He said a local mechanic told him you can get a poly lock nut?
Anyone on the grinding of the valve stems?
Sounds like a half-assed valve job. Since you probably don't want to take the heads off and have the valves reworked anymore, there is a solution. Get poly-locks. Usually used with aftermarket rocker arms. basicly a long nut with an allen set screw inside. At this point you will now be adjusting the lifter preload instead of using the factory positive stops.
I think the Ford fix for this is special short pushrods. Each one must be checked and hopefully you can get pushrods that are short enough to work.
