I have about 2" of lift with nothing but a ford F150 v-8 spring from the middle 70s but I would not recommend it unless you have quite a bit of weight up front, but in the old days its was a common way to get lift and some vendors still sell these repackaged springs.
Specialty spring companies and vendors are better now that they use to be about getting the rate right, but often rate is overlooked to get desired lift, and actually has to be. You cant have a stable ride with very compliant springs and long travel without stiffening them up with the shocks, which really defeats the purpose.
Its all a trade off. I am sure someone will chime in that they have your springs and this shock, and tell you rides great on the highway, but my engineering background tells me that's too much travel in a compliant spring to be stable on the road. Never mind the castor issues you have with that high a lift.
I tried actually have had 4 different coils under mine, but never any other shock that a 1996 F-250 OEM replacement. Cheapest one made. Started way to stiff (vendor recommended), then swapped out for a lower spring rate twice until I hit a good ride. Then went back up to the heavier rate once the 393/700R4 went in. luckily I kept the next step up in springs, I had already sold the super stiff springs.
