Roll Cage Install Advice
vtboy51
I'm fitting my cage to be welded and I realize because the PO welded in some "overlay" floor pans my floor heights are a bit higher than normal. This is a Bronco Bob cage, that has been tacked and fit to a normal bronco, so the front section sits a bit taller because of the shitty floors. I've got two concerns, first the front section sits higher and may cause problems if I put my hard top back on (and it just looks unlevel). Second, if I ever correctly replace the floor pans the cage will not fit properly, it will be angled a bit to high.
I'm trying to determine the best way to solve this, I was thinking of cutting the section of floor directly under the cage foot pad and recessing it down to the original floor, thoughts?? Or maybe I had add an extra 1/4", or so, plate under the mid and rear feet to level it out, then just remove the shims once I replace the floors.... Any advice is greatly appreciated.
Skiddy
doesn't really look out of level, not enough height difference that the top wouldn't fit. but if you want it level shim plates would be the best.
bronkenn
Bronco Guy
Southeast Ohio
I would shim as well. That way when you redo your floors you can remove them. Ken
BGBronco
N A S H V I L L E
Tennessee
I can see the line across the door frame since you mentioned it but 1/4" isn't that much. If you are putting a soft top over it you will never notice it.
Apogee
Tangent, OR
I would shim the rear if it bothers you, as that's the easiest option to undo later.
vtboy51
vtboy51
Thanks for the feedback, I just wanted to be sure I wasn't missing anything as I thought through this problem. I think I'll just add some 1/4" plates under the rear legs, then remove them when I replace my front floors so it will all sit level in the end.
jmangi62
^^^^^ There ya go, answered your own question. I have that same cage and love it. ;)
markatherton
roll cage
If you don't shim up the high spots you will alter your door openings when you crank it down.
67RT
Make sure the floors are securely welded if you are just bolting to them...
sprdv1
REBEL
Good call...
