Roll cage placement
TheVazha
Hi!
I’m mocking up the family roll cage portion, and I will be mounting seat belts to the roll cage.
The existing cage that’s in there seems like it’s pullled back a few inches further than it should be. When I try to mock the family portion, it seems like the rear bar is too far back for seatbelts to be mounted to the bench, and if I mount belts for the front seats to the existing cage, it just seems like it’s a few inches behind where it should be.
What do you guys think?
While I have seen some in the past mounted like yours, you are correct and most of the ones I’ve seen do have the rear feet mounted a little further forward, closer to the back of the wheel well.
Perhaps like many, your old one was a trim-to-fit style and the installer did not trim.
More than likely you can do that to your new tubes as well to suit your tastes and needs. But you can perhaps also do some trimming where the old one was not, in order to move it further forward to suit your needs.
Unbolt the rear kickers and see what they might let you do to help with the new install.
Regarding your seatbelts, don’t assume that anyone designed any part of your old, or new cage bars to accommodate a seatbelt mount in exactly the proper location.
They were probably originally designed before anybody had even heard of 3-point shoulder belts. Modern vehicles have adjustable ones for height, whereas once you weld on a tab or mark a location to drill for a bolt, that’s where they are going to be whether the driver and passenger are tall, short or somewhere in between.
BGBronco
N A S H V I L L E
Tennessee
I'd say you need to move it up 4" - 6", definitely if you are adding a family cage and have a soft top. You can use ratchet straps to mock it up / see how it will fit together.
T
TheVazha
Amazing thank you! I’m scratching my head trying to figure out how to mock it with woodworking clamps. Lol
NYC Bronco
I recently did this, removed the OEM style roll bar and replaced with a Krawlers edge Sport. I think you never know what the PO did and or how "square" the body was when it was done. WE probable spent three or more hours moving the KE cage around till it was square enough. Any Bronco that is in use and not being rebuilt from the ground up is going to have "uneven" imperfections and body/frame flex.
