rotating knuckles to gain caster HELP!
U
Unregistered
Guest
I have just started to grind the welds off the inside of the knuckles.Question,From what I can tell I have ground off all the weld and I still cant find the joint,what am I doing wrong?If anyone out there has done this mod any advise would be welcome.thanks.Curt
swingle61
Greeley, Co.
The knuckles are a very tight press fit to the tubes even before they're welded. Once the weld is ground out fully, Take a BFH and beat on the knuckles till they braek free. It will take alot of force to get thm to move. If you've beat on them for a while with on progress get the grinder back out. On mine I thought I had ground enough but I finally saw the seam and then the BF hammer did the trick. Good luck with you project.:cool:
U
Unregistered
Guest
Thanks alot for the help.Did you find the seam before or after using the bfh?I have ground off quite a bit and still dont see the seam.
lars
Been here awhile
NorCal flatlands
I cut n' re-welded mine last fall. I used a carbon air-arc torch to cut out the welds. We cut out a huge amount of material and never did really see the seam. There's no way the knuckle would have moved with just a BFH. We wound up using a 10 foot piece of steel as a lever, and even then had to heat the thing with a torch before it budged. Passenger side was more difficult than the drivers side- tighter press fit, apparently. I've talked to a couple of other guys who have done it and had that same experience. Pics of what I did here: http://www.broncofix.com/board/viewtopic.php?t=2842
Well worth the (huge) trouble, IMHO. It's still no Porsche, but the steering is less vague and self centers better than it ever did, even compared to when my Bronco was stock.
U
Unregistered
Guest
Thanks to all for the help.I have alot more to grind off!
ballistic64
Piedmont , SD
Man,I dont envy you.Try to find a buddy with access to an air arc.I arced mine out a few weeks ago and the "seam" your looking for is deep.A couple other members have said theyve done it with grinders and die grinders but its gotta be a real PITA.
Madgyver
Bronco Madman
Why not just cut it square and bevel the ends to penetrate a good butt weld to connect the two?
If you can align it perfect I can't see why it can't be butt welded. Is it because people may not be comfortable driving the rig with the axle tube connection being it was butt welded?
We have more important parts/components that are welded to the frame that holds our rigs together with a simple bead of weld.
Any experienced certified welder can do a strong butt weld stronger than the tube itself.
Has anyone thought or done it this way?
tonto
That’s how I’ve seen it done and I plan on doing it, with an alignment bar through the housing and a fixture that duplicates the spindle on the knuckle with out the snout of the spindle with a hole in the center the dia. of the alignment bar, push the knuckle attached to the C onto the alignment bar sticking out of the end of the axle tube.
Set your pinion angle clamp or tack weld to the table and then set you castor on your knuckle and tack around the tube a few times and then go for it while a friend rotates the axle slowly and you weld.
It you want, put a gusset on the bottom of the tube where the C attaches for some insurance.
U
Unregistered
Guest
the knuckles are off!only took 5 grinding disc. once I found the seam following it was easy,after that a big hammer cracked the weld.Im so happy!5.5"of lift with a good pinion angle and positive caster Yahoo!thanks again for the help.Curt
ballistic64
Piedmont , SD
When you lift your Bronc you lose your caster angle.This can be corrected with different "C" bushings,but on lifts of about 4.5" and higher your kinda SOL by trying to correct it with C bushings alone.You can get close but not quite.While you can live with the neg. caster a lot of people choose to correct it and the pinion angle at the same time.This involves using a smaller degree C bushing to point the frt. diff. pinion at the transfer case and rotating the knuckles to a better caster angle.While C bushings can help correct caster issues with a lift kit,they do nothing for the lost pinion angle and usually make it worse.Some of this might be nitpicking to some people,but with a 4.5" lift or higher on the highway I can guarantee youll notice a difference with a positive 4-5 degree caster angle.
