wesleydax
- Apr 12, 2011
- 331
For what ever reason i can not wrap my mind around rotating the knuckles. i just finished new 7degree bushings, all new rear spring bushings, track bar frame mounting hole was worn so i fixed that and installed new bushings. new steering stabilizer. it is driving a lot better and is going to allinment shop this week to see where im at. my question is how mush caster do i need? is it better to use drop brackets on the radius arms or rotate the knuckles? if you rotate the knuckles how do you know the right amount of rotation? in my mind im thinking set axle on stand get it plumb then use degress gauge to move knuckles back to a certain degree. I think.
