pipeline010
- Nov 15, 2017
- 618
pulled the carb. the ring around the power valve was totally dry. I swapped with the old one and the only change (on test drive) was that the truck dragged a little a$$ on speedy acceleration. Seems the new PV was doing its job. Too dark, so I'll swap back tomorrow.
Ok good to know about that blue thing. I'll pull it, I'm all about clean engine bays these days.
Plugs are the ones I've used since getting the truck. Prior to the new diz it ran absolutely perfect. I don't think its the plugs.
vacuum is good. holds with a very slightly bouncy needle at 20-22. The only vacuum items I have are standard and simple. Booster, PCV, etc.
vacuum advance is attached to the port on the left side of the carb (facing from front of truck). It works exceptionally well, tons of movement at speed.
I feel like I've done pretty much everything at this point..
