Rubber mat or Carpet??
kat
Bristol
I have a '76 Half Cab that the floor is fiberglassed (inside) but I want to get rid of the heat and noise. Was looking at the rubber mats that the vendors sell but don't know if they are thick enough to solve my problem. I have heard of people getting some stuff from Lowes to put under them to help but can't remember the name of it.
I like the look of carpet and I know this is the quietest/coolest solution but the ol girl sees a lot of water during the summer (bikini top) and I know what carpet does when it gets wet.
So what is a good solution??....Im thinking the mats like this
https://www.wildhorses4x4.com/product/OEM-Front-Rubber-Floor-Mat-with-Bronco-Script/Bronco_Carpet
blubuckaroo
Grease Monkey
Ridgefield WA
Instead of rubber, I'd use vinyl flooring.
Give ACC (Auto Custom Carpets) a call.
Their vinyl is really thick, and comes in several colors.
Their flooring is actually heat formed into a floor pan of whatever car you are working on.
Nothing Special
I've heard good things about the Lowe's / Home Depot product too, but I don't remember the name either.
For carpeting I've been intrigued by a product called "BedRug". I've seen it as a pickup bed liner, but it looks and feels like carpet. Supposedly it hold up really well to weather, spills, and physical abuse. But I've never really looked into it.
roundhouse
We put FatMat in my sons 76 K-10 and it eliminated all the road noise and heat
70sbudget
It's in the air conditioning and heating section and meant to insulate ducting. Grab a few rolls and have at it
kat
kat
Bristol
Thats it...Peel and Seal. With that under a good rubber mat should do the trick right?? I know the Peel and Seal should be sticky but with the rubber mat over it everything should stay in place. Would I need things for the door jams to hold the mat in place??
1strodeo
Squirrel Watcher
Wisconsin
^^ this is what I used when I replaced the floorpan in my Mustang
If it has a trademark name (like Peel & Seal) it's more $$$ :)
1strodeo
Squirrel Watcher
Wisconsin
Thanks blu I will check that out whenever I get my Bronco back
Slowleak
Georgia
The Peel and Seal is aluminum backed. You might want trims strips in the doors to hold the mat in place.
https://www.lowes.com/pd/Peel-Seal-...s-6-in-x-25-ft-Aluminum-Roll-Flashing/1018733
This is the foam and aluminum duct wrap. I got mine at Home Depot.
https://www.homedepot.com/p/E-O-12-in-x-15-ft-Self-Stick-Foam-Foil-Duct-Insulation-FV516/100028603
One is asphalt backed, the other is closed cell foam.
BGBronco
N A S H V I L L E
Tennessee
Debating this as well. I have a good mat in the bronco now but thinking about adding carpet to upgrade the interior look. That said, I agree with all of the reasons people mentioned to not do carpet.
jmangi62
Wow, some good reccomendations for sure, but what I did was replace all bad metal, prepped for spray in liner (which I did myself), then went with Toms complete deluxe carpet kit, and it was a very nice kit, I highly recommend it, great fit and nice quality padding and seamless carpet. Came out great. ;)
nvrstuk
PNW
I've tried about everything but spray in liner (I rolled Herculiner in back in the late '90's) and.
--2 layers of stock Lincoln jute padding with full carpeting installed professsionally with Peel and Seal type alum backed insulation on the firewall
--Dyna Mat
-- body lift
-- with my build I made heat shields spaced 1/2" from the floor from appr the top of the header to the rear wheel wells--
http://classicbroncos.com/forums/showthread.php?t=278607
NO comparison at all...heat shields don't let ANY heat by. I've only tested them for a week running trails in Moab including plus another week of cruising easy trails with my wife in it.
We've had several 4 hour runs with only a brief stop or two. You can put your hands on the floor and it barely feels warm...not quite the 150+deg F heat ALL over the tunnel and floor when I was doing the radiator torture test!
Hands down, we know why all manufacturers use heat shields instead of easy stick on mats!!
So far, so good!!!
blubuckaroo
Grease Monkey
Ridgefield WA
kat
kat
Bristol
Just ask them to let the firewall run long. If you notice, some kits don't cover that area all the way up.
ACC will leave the edges long if you request it.
Ok, now I don't know what I want. When I first seen vinyl I though 'no' but after looking at it I might go that route. But the rubber mats seem a little thicker. I have determined I will most likely use the Fat Mat as someone has suggested for the noise/heat
