Rubber mat or Carpet??
gnpenning
Bronco Slave
So which would be better the one that has the foam backing?????
There has been a fair amount of debate on this in the past.
Peel and seal should NOT be used close to a heat source. Some complain of smell some say no problem. I bought Some and put a strip in one of my trucks. While not much I haven't smelled anything for a couple years. I don't live in Arizona either. Not a great test.
I'm going to use ceramic beads and the foam on the fire wall. Inside my doors I'll use the peel and seal based on my" test" and I think it has better adhesive. I don't know if the foam would hold up on the floor ?? It's not designed for traffic areas where it will be rubbed against or floor mats moving.
I think you will find pro's and cons to both. I know not much help.
JefeAZ
Tucson
Ok, now I don't know what I want. When I first seen vinyl I though 'no' but after looking at it I might go that route. But the rubber mats seem a little thicker. I have determined I will most likely use the Fat Mat as someone has suggested for the noise/heat
I can take some photos tomorrow of the material and Ill put them up on Monday. The vinyl is pretty thin so it can conform to the floorboard but comes with padding for the front seat area. I have rhino-lining and sound deadener plus no hard top so Im not worried about it.
kat
kat
Bristol
Thanks that would be great because I want to order something in the beginning of the week
roundhouse
I take the top and doors off on the summer so I guess I could have used carpet
But didn't want it getting wet all the time
The carpet will dry out pretty good but the jute padding will not dry out ever
You have to take it out and throw it away
The exhaust pipes in mine burned the paint off the floorboard
I got some insulation from underneath the cab of a cabover 18 wheeler
And used that along with some closed cell foam under my vinyl floor
That made a huge difference in the heat
Shields are also a good idea
kat
kat
Bristol
Just a thought but has anyone ever put heat shield UNDER the body floorboards??..
JefeAZ
Tucson
Here are photos of the ACC/StockInteriors vinyl kit
Talking about that here, its a great idea:
http://classicbroncos.com/forums/showthread.php?t=281504
sykanr0ng
How did you get the thread to show up with the topic name rather than the url like mine above? ;D
Copy and paste the thread name into the reply box.
Copy the url.
Use the mouse to highlight the thread name, like when using a different color text.
Click the Insert Link button (under the Smilies button) and paste the url in the pop-up box that opens.
nvrstuk
PNW
I did. On my build thread it shows a few pics of the aluminum heat shields that I mounted from firewall to behind the front seats.
It's here somewhere... http://classicbroncos.com/forums/showthread.php?t=278607
I just got home from our maiden trip and still upacking...but, I can tell you they make a HECK of a difference.
How many manufacturers try block the heat now with heat shields rather than try to slow it down after it's heated the body and sheetmetal...
kat
kat
Bristol
That is one helleva build you got. Do you have a good pic of the shields on??
nvrstuk
PNW
Thanks...
I just returned from Moab a couple hours ago... I will get some pics tomorrow but as you can tell if you saw the last 3 weeks of build thread...the posts and pics were getting a bit thin because I literally didn't have time...I worked 16-18 hr days/7 days/wk and before that, only 14hr/days/7days/week since July...I have tons of pics and will update.
IF i don't post tomorrow, PM and I'll get on it... : )
Outdoorfunguy85
Instead of rubber, I'd use vinyl flooring.
Give ACC (Auto Custom Carpets) a call.
Their vinyl is really thick, and comes in several colors.
Their flooring is actually heat formed into a floor pan of whatever car you are working on.
I will use vinyl too. I will ask help from Gatorwraps how to do it.
kat
kat
Bristol
Thanks...
Thanks man
