Running without the gauges hooked up?
clinem03
I just pulled the gauges out of my 76 Bronco. I was under the impression that I could start and drive the bronco without the gauges, and since I am about to paint her I wanted to strip out all that I could to prep her before paint. I also planned to have the gauge refurbished.
Gauges are out, and now she won’t start. Nothing happens when I turn the ignition so I assume that something, or everything, on the gauges needs to be connected for her to start and run. Outside of completely reinstalling the gauges, what can I hook up to get her running again? I only need to move her in and out of the garage and I’ll need the body/paint shop to be able to liver her around. I don’t plan for long road trips without gauges :)
Thanks in advance for the help!!
clinem03
clinem03
Never mind, I figured it out! It was the large yellow/black wire reconnecting to the red/black wire. Forgives since it was secured through the loop on the backside of the gauge that it was for safety reasons. Easy peasy.
Glad you got it figured. Yep, without that wire intact nothing works at all.
The good part about you having it apart though is you can check it's condition. Most of them are in extremely good shape at that bullet-connector, but some I've seen were starting to rust over pretty good. And I can assure you that you don't want that wire compromised in any way!
If it's starting to crust over or is even just a bit dirty because the connector was not pushed all the way together, clean it up the best you can before putting it back the final time.
clinem03
clinem03
Thanks, Paul! Like most things on this truck, the wire is super clean and showing no signs on rust or decay. All the wires have a bit of that "barn dust" on them, so I''ll for sure clean them up before reinstalling my rebuilt gage cluster :)
