Sanding Tools
Dbarnes72
Eastern Wa.
Getting very close to starting to finish.........filler and sanding. I own a Home Depot DA but need some real world advice on purchasing sanding tools. I don't see doing bodywork after this Bronco so I don't want to invest in long term/high dollar air tools. Is there a middle of the road approach. Looking at those Dura Block tools. Maybe a long board hand sander. Any suggestions?
Recently did a boat (very similar shapes (curves and flats) to a Bronco. DA was not used much, but I put a lot of miles on the inline sander.
Pa PITT
Stephenville TEXAS
.. I Sold them for 30 years. Sorry but I need to reach back a long ways here.
... The long Skinny Air Board.. I have 2... The best one is A Hutchinson .. It has more RPM. It moves both way back & fourth & side to side. It uses the 18..... or 17 3/4 by 2 3/4 paper end clip paper..
..... & WITH both of these tools the no 36 grit paper is much faster than the 40 gr.
Then move onto the 80 gr & up from there.
... 2ND Tool is Something like a Ron-co . or so. It used a 2 by 18 +r- paper . It only moves back & fourth. Much cheaper but not as good a tool. But you can get up next to a line with it & not scratch the chrome.
... The Fancy new Velcro paper is really sweet but You need to be able to steal it .. As It's so expensive .
.... Those 2 are more for taking down bondo for body work.
.... The Da's .. I think I have 2 of these also .. I haven't used them in 10 years. But plan to ASAP. On my ROJO Project.
... But when buying a DA ... some HAVE A BUTTON that you Lock into place. One of mine will knock your finger nail off.. IT'LL ALMOST REMOVE THE TIP OF YOUR FINGER when your wrap your hand too far over it. I've done it several times.
... So if you buy a DA.. PUT YOUR HAND OVER IT & Spin the disk by hand & see if it can get to you Center finger.. Trust me it hurts.
Rickb1b
I'm no expert (painted maybe 15 cars). I don't use a DA, I use a dewalt orbital sander. I think it works just as good if not better and can be used on wood or anything else later on. For long straight panels I use an air inline sander, but used a hand long board for years.
TN1776
Air inline sanders are so nice to use, and the harbor freight variety would probably do just fine for your needs. I borrowed a high dollar air sander from a friend while doing mine.
Otherwise, a nice long wooden hand sander does a good job too. More effort but equally nice results. You'll probably need some foam blocks too.
englewoodcowboy
Lick Creek Restorations
There are few surfaces you can use a DA on, mostly doors, hood and roof is about it. Get a good set of blocks. Hand sanding will be your best way.
Hozr
Rogue Valley, OR
The durablocks are great. The DA will cause waves as will pneumatic sanding boards unless you are VERY skilled with them.
  • Buy lots of sandpaper and change it often.
  • Don't press down, just slide the paper across the body and let the paper do the work.
  • Alternate directions (i like diagonals)
  • Only sand until the marks from the previous grit are not visible any longer
  • BE PATIENT!
allenfahey
I use Dynabrade DA's. I used to use Hutchkins but Dynabrades last longer. Whichever DA you choose you will find there are three different size patterns.
3/8" good for body work and stripping paint
3/16" good for general bodywork and paint prep
3/32" good for fine sanding. I use it to sand for buffing with 1500-5000 grit
I suggest getting a 3/16" pattern. If as you say you are only going to use it once get a cheap one. What I do is on the first use only use a little oil. Then I never oil it again. Oil and paint prep don't mix well. I'm not sure how long a cheap DA would last like that but I get a little over a year out of my Dynabrade DA.
I like using hookit sandpaper. It last longer than stick-it because it stays cooler.
The Durablocks are great.
Rustytruck
Man I just used 3 different lengths of rubber sanding blocks and one standard rubber block cut into a 1/3 and 2/3 pieces and wet sanded all of it by hand. 4-1/2 inch grinder for grinding up for Bondo and a Porter Cable orbital sander/buffer for buffing after color sanding for final paint work. There's nothing flat on a Bronco just a bunch of compound curves. Power tools without allot of experience just want to cut everything flat. Allot of it is just learning when to stop so you don't have to add more filler and go over it again.
Dbarnes72
Dbarnes72
Eastern Wa.
Thanks all. Sounds like hand sanding hands down. I've got a couple of small waves in the middle of both lower rear quarters where I (attempted) to pull them into shape. So I will definitely be doing some filling and smoothing. Dura Blocks it is.
