Some progress the past few days - I got it running good enough to get it on the lift to start the brake job. It took a new fuel pump, new distributor, new coil and a build of the carb to get it running. The brakes look terrible! the rear passenger side is full of either 90 wt oil from a leaking axle seal or brake fluid from a leaking wheel cylinder - not sure which yet. The front passenger hub was full of water and the bearings were pretty much rusted up. Anyway, got the parts on order and I'm in the process of cleaning the parts now. I also got the carpeting pulled out, the interior cleaned up some and the front seats re-installed. Worst part was getting the all glue that held the carpet in removed.
