Sealant for nine inch diff?
roundhouse
What sealer do y'all recommend for the nine inch diff ?
Or just use the gasket ?
blubuckaroo
Grease Monkey
Ridgefield WA
Many here use "The Right Stuff" sealant by itself.
This will certainly be cause for debate, but I'm concerned that the gasket thickness might be important in positioning the spiders in line with the wheel bearings.
I like to use the gasket and just wet it with RTV sealant, and haven't had a problem with this method.
Be sure to use new copper sealing washers too.;)
englewoodcowboy
Lick Creek Restorations
I ditch the gaskets and only use RTV. Never had an issue and the potential of misalignment is so minute that it is still well within spec.
70_Steve
Old Guy
I seem to use #2 Permatex for just about everything. So... I use a gasket and just skim coat both sides with the Permatex.
B RON CO
Statesville, NC
Hi, I've used blue and black permatex by itself and with gaskets, always with good results. The new style gaskets come off very easy, that was the problem in the old days, getting all of the gasket off. X2 copper washers. Get that sucker off your chest and into place and start to snug those bolts in a big criss cross pattern. Double check them all because a couple of those nuts like to hide from you. Good luck
Sledneck
Lube Locker gaskets. Have them on everything I work on, and able to remove and reinstall many times without issue. And no cleanup after disassembly. Well worth the money to me.
broncoman1972
They are there to seal around the threads of the studs that are pressed through the housing. Without them fluid can seep passed at the studs.
Sent on the fly
broncaholic
When I had my rear diff rebuilt around 12 years ago, Vince Parisi at Fearless Gear, Fresno California, gave me a tube of pure silicone. As I remember, it was in a gray and white tube and it is still holding tight. Wish I could remember the brand.
ntsqd
heratic car camper
Upper SoKA
Another vote for The Right Stuff. With all of the nuts and washer removed you'll still need a prybar w/ some effort or a jack to pop the diff loose the next time it has to come out.
R
roundhouse
Ordered the lube locker gasket
Looks like the ones GM uses on the LS motors
t120r
I've never had a gasket that didn't weep. I'll be using sealant next time.
