Sealant for nine inch diff?
Yeller
Rogers County Oklahoma
Ordered the lube locker gasket /QUOTE]
on the promod cone dodger (runs 10 minutes at a time, but it a quality 10 minutes;D) we use them on it and it gets run hard enough that the studs will work loose, we know there loose when it starts weeping, tighten them up and its good for another year.
ntsqd
heratic car camper
Upper SoKA
Yeller,
Seems to me that if you're using some sort of lock-nut (& if nylox they aren't re-used more than once, at most) that the only way they're getting loose is if the gasket is compressing or the studs are stretching. Neither is good, but the latter is particularly bad because that means that they're about to fail. Does ARP make these studs?
Which begs the question, what type of nuts are folks using here?
Thinking on this a little more, copper washers don't seal to the threads themselves very well. With a normal nut oil can still work it's way out thru the thread clearance. A nylox nut probably will seal in these conditions (no real pressure), but I doubt an all metal lock nut (like a "Stover" nut or similar) will seal very well.
Stat-o-Seals and Dowty washers both are metal washers with an o-ring like seal vulcanized into the ID.
Stat-o-Seal's: https://www.pegasusautoracing.com/productselection.asp?Product=3245
Dowty Seal: http://www.mcmaster.com/#93781a037/=13h8xz8 (mcmaster also carries stat-o-seals)
Yeller
Yeller,
We actually only have a couple of studs to hang the diff on for installation. the rest are bolts. We have aftermarket housings that are threaded. We use the bolts and no self locking devices with the theory that with the short runs its not a liablitly and the abuse it takes if we have to open a diff between courses, its faster, easier to not deal with the studs and lock nuts, so in that application they are working loose and not stretching. The chunks and housings do get a lot of heavy massaging on rocks too which does not help.
Steve83
...washers don't seal to the threads themselves very well. With a normal nut oil can still work it's way out thru the thread clearance.
That's why you should be using a thread sealant, just like on the flywheel/flexplate. Thread lockers are excellent thread sealers (red for most people; blue if you have to remove the chunk frequently), but so are most of the other chemicals that have been mentioned in this thread. %)
ntsqd
heratic car camper
Upper SoKA
FWIW can buy G8 bolts with a nylon button in the threads. More security with no loss of easy R&R.
Thread locker as a thread sealant is a crap-shoot. Sometimes it seals, sometimes it doesn't. 545 is a thread sealant, but is on the very low end of acting as a thread locker. As 545 is not inexpensive I'll stick with some type of sealing washer and, if needed, nylox nuts.
