Sealant is only used on taper pipe threads. Both NPT & NPTF. Straight threaded fittings rely on the taper seat to seal, not the threads. I've fired technicians for using Teflon tape on straight threaded hydraulic fittings. Just ignorant workmanship.
However, the conical, fitting seat that contacts the tubing flare may gall at assembly. This is more true of stainless brake components. So, I always use anti seize on the fittings and bleeder screws. Also prevents rust on carbon steel junctions. Water will follow vertical running lines and collect between the line & fitting. Doesn't take long to rust into a solid mass.
