Secondary hood latch that doesn't interfere
kkelly10
Hey guys, so I made some cuts on the core support and pushed the radiator and a condenser out farther forward than stock. I needed to do this to clear the front pulley system. Because of this I couldn't use the stock hood release mechanism, so I put a BCB remote one for the primary. My problem is how to handle the secondary hood release. The rear facing hook will impact the condenser so I need one that points toward the passenger side. Any ideas?
Don’t have any answers or suggestions for you. But back to the top to hopefully get some more reviews.
rcmbronc
Tomah WI
I dont know of another idea. I moved mine forward all the way so it would clear the rad. You may have to put a small plate over the back side of the hole in the core support and move the latch way forward.
That’s a great idea! Hope it works for the OP.
Have you done it that way yourself?
You the traditional fix for modifying a core support and latch area is to simply use hood pins. Not my favorite idea, but maybe it is still one potential option.
56f100bbw
Tucson / lakeside AZ
I modified a hood latch off a Ford Taurus works well my 77 and my 76 bronco ., I drilled out the holes slightly so it would mount to the hood I modify the lever a little bit. I guess the hard part was the plate with a slot in it in the radiator support. The reason I did this was lever hitting the condenser. on my 76 bronco I bought a remote hood release from Randy and driven auto probably 20 years ago still works great.
kkelly10
kkelly10
Great ideas guys! Let you know how I solve this, but liking the look of that Taurus one.
dmoses42
Bronco addict
Brunswick, Ga
I'm guessing you've had that remote hood release latch for a while? Every time I look on the BC Broncos website, it is always out of stock. Sure would be nice if they kept this in stock. I'd love to pick one up.
Speedrdr
OLD night owl
Paris, MS
What year/years of the Taurus did you use for this conversion to remote release? TIA
Randy
Speedrdr
OLD night owl
Paris, MS
Thanks! It’s looking like I’m gonna have to move my core support a ‘whisker’ or two to get clearance. With how I’m welding right now, I might get 3 to make a successful latch. Lol
Randy
