- Jun 4, 2002
- 37,112
OK, went through my milk crate of stuff from SEMA (at least most of it anyway)
Picked out some highlight stuff that mayinterest some of us Bronco people
Painless has a revised Bronco harness. Much nicer then the old. New covered fuse panel that includes a glove box liner that it mounts into. Uses stock ignition switch, headlight switch, wiper switch. Stock molded plugs for the tail light buckets. I think it will set a new bar for aftermarket harnesses in Broncos.
Daystar will come out with some D-ring isolators for those of you annoyed by the D-rings clanging against the bumpers at $10. They are also doing roller winch replacment rollers for synthetick winch line. set of 4 rollers for $40.
Highlift has a booty to cover the working parts of the jack.
ARB had brochures (but no product) of the new redisigned freezer fridge. Front control panel, locking power cords, recessed handles, but the same great performance. They also showed off some more compressors. New one is half the size of the one on the air lift air ride kits and pump twice the air. I asked about noise and they said they made improvments. Completely sealed and the air filter (sintered bronze) is threaded in so you can relocate it to a higher location. This way you can mount the compressor down under the rig and still feed it fresh air.
Spal had a nice variable speed fan controller for those running electric fans. Gives a variable speed besides the on/off that the normal switches do.
For you engine heads, www.compu-tronix.com has a small block 302 and 351 distributorless ignition distributor drop-in. Stand alone to work with carbs. Not for EEC-IV computers yet.
AFR is coming out with a nice 12½° small block head that flows 300+ CFM @ .550" lift. They just had the rapid prototype there but expect that in about a year. Not really the ideal trail rig head, but if you want HP then you know that it is in the heads.
Picked up some www.rescuetape.com to replenish my supply.
Also got one of www.clamptitetools.com as I have seen one a while ago and wanted one. Got to try it in person at the demo. This will make some tight wire bindings fairly easily. Watching the demo in person it looked easy, my first attemp I fumbled a little but still made a good clamp. That was enough, I got one.
That about does it for highlights. No early Broncos at the show (again). It was really downsized this year. But the real car people were still there. That is about it. See if anyone else who went has anything to add. I only spent about a day and a half at the show so I know I didn't see everything.
