Yesterday the Bronco came home on a shiny new $118K flatbed. I pulled the stock distributor this morning. The drive gear had a pin in it that appeared to be about 3 layers of rolled sheet metal not the "conventional" black c shaped split pin. The pin hole in the dist shaft is is oblong and at least .010 out of round. The gear pin hole is still round and 1/8 in dia. The drive gear teeth are shiny on one side with no apparent wear. The shaft of the distributor is knurled (re-builder?) under the upper half of the gear which is just the boss that the split pin goes into. There is no support under the gear teeth. Actually is has about .004 slop that would allow the gear to wobble on the shaft and weaken the roll pin when it was under load pumping lots of oil. It was a rebuild from the local auto parts. Engine has about 10K since it was rebuilt. I am debating whether to put in a stock pump or leave the HV pump in after I go fishing for some little pieces of roll pin that are in the pan.
I don't need an after market hot rod distributor. A new stock re-placement would be fine or a rebuilt that was re-built to last with a new shaft and gear that is tight on the shaft. Anyone know of a quality re-builder or a stock Made in USA replacement? I have had no experience with either Mallory or Pertronix other than the pickup now in the stock distributor. Does anyone have any preference for a stock replacement?
I had what I thought was a stock new oil pump on the shelf. Looking at the casting it has "M68HV" and the strange letters "USA" cast in the side. I assume it is another HV Melling pump like I have in the engine
