- Apr 21, 2013
- 3,178
Driving my '66 that has a 5.0 EFI engine and after switching to second gear, engine went dead.
One of first things I did to troubleshoot was remove distributor cap and see if rotor was able to turn by hand. I did this because I suspected a distributor problem. I could turn it. Got it home and pulled dizzy to find sheared roll pin allowing gear to spin on shaft.
Question - You think that this is just a simple "pin the gear back to dist and drop it back in, at proper timing location" and it will be fixed? I'm thinking yes because if oil pump seized and caused pin shear, I couldn't have turned rotor. What do you think?
Norm
Norm
