Shift kit removal
jckkys
Is there an all inclusive instruction that describes returning a C4 to a pre shift kit condition. A knuckle head bench builder at my local transmission shop puts Transgo Shift kits in ALL his rebuilds without the owner's request, permission ,or knowledge. They call it a shift improver kit. It didn't improve anything. On a less than 1/4 throttle acceleration from a stop it chirps the tires on 1 to 2 shifts. Until this was done, the C4 had nice firm shifts at the appropriate RPMs. I know one of the shift kit modifications was drilling a hole in the separator plate. Will I have to have it welded? I also know some of the parts were removed and replacing them may require purchasing another valve body. How do I tell one that's un-molested?
J
jckkys
Is there no one who knows how to return a C4 to original after a shift kit was installed? Or is the sales pitch of shift kit makers so effective that everyone thinks that this always a good modification. If it was, manufacturers would have incorporated them in new transmissions.
pcf_mark
I was sorry after I installed one too - the 1-2 shift was too harsh for around town driving. No way to go back unless you have the parts and I think you would need a new plate in the valve body because you drill a hole larger.
Not that you asked but I am 1,000,000% happier with my 4R70W than I ever was with the C4. Sure it took a lot of work but less than the two times I rebuilt the C4.
Slowleak
Georgia
It’s pretty common to remove the “hockey puck” when the kits are installed. The purpose of the puck is to soften the 1-2 shift. Reinstalling it will help a lot.
burnout
Don't weld the separator plate, it will warp and be useless. You can slightly reduce the size of an orifice by putting a steel ball (bearing or ck ball) on the hole over a hard surface and strike it with a hammer. A good place to start would be to get a stock separator plate and a stock pressure regulator spring for your year C4. Better yet, get the bozo to give you the instructions for the shift kit that he put in. There's a help line phone number in there. You can call TransGo and ask them for help, they are friendly and give good advice. They want you to be happy with your trans so it's worth a try. They're on the west coast so call at the right time. I've put in a lot of shift kits and I always leaned towards the smoother side of firm shifts unless a customer requested tire chirping shifts. And many times when they ask for shifts to slam, they were back in a month wanting to back it off. A good shift reduces the time it takes to transition from one gear to the next. harsh shifts are usually just the result of too much overlap in shift timing. JMHO
J
jckkys
burnout; Thanks, your advice is excellent. Today I talked to local shops and found out that EBs had different C4s than those in cars or other trucks. Just as I had experienced in my '74 and '77. These C4s came with a much firmer shift from the factory. This confirms my experience. I bought a new '73 Maverick also with a 302/C4 before the '74 Bronco. The C4 in the Maverick had a very soft shift. It did need a shift kit. The '74 Bronco didn't. I doubt there are many on the forum that owned a new C4 equipped Bronco. There are more that had C4s in other vehicles or only experienced C4s in Broncos that have been rebuilt several times. Many of those have had shift kits installed by previous owners. In This;https://classicbroncos.com/forums/showthread.php?t=224173, thread 6 yrs. ago, some considered this fact. Now the false idea that all C4s NEED a shift kit appears universal.
I have a hopefully unmolested '74 valve body from the junk yard and will disassemble it tomorrow.I also got the Transgo instruction sheet to help identify original vs. shift kit parts.
