- Mar 28, 2012
- 3,559
It's not the same thing. A shorter shifter isn't the same as a shorter throw. The difference is in the length below the pivot point.
With their shifter you must use the Lokar adaptor. A short shifter is a combo of both the shifter length above pivot point as well as below.
The Lokar adaptor has 2 pivot points pre-drilled (as seen on the picture) on the link. Stock and short. Use the short hole for the rotation and cut the bottom 2 inches off their shift handle (it's already drilled for regular and short throw) and you have a nice short shifter with a short throw. Or, do one and not the other to make it a short shifter but not a short a throw.
http://www.dufftuff.com/NV3550_Manual_Shifter_Lever_Adapter_p/2141.htm
