Shimmy over 55 mph
Ohio Bronco 21
Cleveland
I was wondering if any of you had issues on your alignment when you went to bigger tires. I was running some approx. 30 inch tires with a mild tread and had no real problem with my toe in on my wheels. I put some 35's on and now just looking at the front of the truck I can see that while the drivers front wheel is about straight on, the passenger front wheel is outward. I know they should toe in somewaht toward each other. Driving the Bronco it shimmys over 55 mph in the front end (steering wheel shaking also).
Seems straight forward, just toe both wheels in right? Why would I have not had the shimmy problem on much smaller non aggressive tread tires?
I did just use Dyna Beads to balance the tires also, all seem good but one on the rear of the vehicle ( I am going to take it to be lead weight balanced on a machine in addition to the Dyna Beads). Any thoughts?
Oh, also, too tighten (toe in the wheels) what direction do I turn the sleeve?
mustangtoby
southwest Colorado
You probably can't see the toe in with the naked eye, even if you could the steering wheel could be turned one side or the other a little bit. Get under it with a tape measure and check front to back, should be toe'd in about 1/8". Pretty hard to measure accuratly (sp?), though. Or take it in to a shop, could save you a set of tires.
Were these new tires Ohio? Or used? Can make a huge difference.
Either way, yes, a tire with a more aggressive tread can give you all sorts of monkey motion when you don't want it. Most can be "aligned" out, but sometimes a tread pattern is just so bad (more often on a used tire though) that you're going to feel the wiggling/squirming.
First do what Toby suggested and either check your toe-in very carefully, or have a shop do it.
Also, have you fiddled with the air pressure?
For our info, what type of tire, and what size exactly? I know you said 35, but I'd be curious to know the other specifics.
Sorry I can't remember just which way to turn the sleeve, but you should be able to tell quickly, if you're doing it right or wrong. Besides, if it hasn't been done in awhile (like it's whole life maybe?) then the hardest part will be getting the bugger loose! If it holds true to form, you could start another thread just on how to get a Bronco tie-rod sleeve to turn. Fun fun.
But if you're measureing, rather than going by eye, it won't matter if the first turn is wrong or right, you'll see it reflected in the measurements. And if you keep track of how far you turn, you can re-trace your steps and correct any mis-steps. You don't need much of a turn on the thing to make a noticeable change.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Thanks guys. These are used tires with most of their tread, no irregular wear on them. They are 35 x12.50 x 15 Bf Goodrich At's. The weights had been knocked off or were about to fall off, I removed them and used the Dyna beads. I am going to take them in for speed balancing.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Well, I adjusted the toe in some and the vibrating etc, got much worse. I moved it back to where it was and it dropped down somewhat (vibrating).
I tried to balance the wheels at a shop and the high speed balancer kept saying well over 12 ounces of weight (wouldnt balance). Tires maybe had been sitting? This sucks, everything is great till 50 mph.
mustangtoby
southwest Colorado
Just a thought, but how did you get the used tires? I got a set of super swamper SSR's from a guy who gave me a hell of a deal, never been on the ground. Turned out they wouldn't balance, soon as I put them on I found out why he wouldn't use them and sold them. They ran out fine until about 45-50 MPH, then would get to bouncing. Tried balancing them, machine said they needed 24 ounces on one of them! Tried bead in them, didn't work. So I bought new tires, sold the SSR's (I did give up the reason I was selling them, the kid who bought them just wanted them for mudding and knew what he was getting). Been great ever since!
RV77
Springfield,IL
Your wheel isnt hitting the tie-rods is it ? When I put my 33's on my rh wheel was rubbing on the tie-rod
I forgot to ask what wheels you were using too, Ohio. Just wondering if you mounted the new tires on the same rims, and if so, what size and condition they were.
Not that there's much doubt know that the tires themselves are the main issue, but I was curious.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
I bought the tires and wheels, mickey thompson classics off a guy on craigs list. Rims are in nice shape. I got them pretty cheap. Ill probably put them on a trail truck or sell them as trail truck wheels.
