My old 71 with Kentrol tub. Tailgate and Windsheild frame were also fiberglass, doors were not.
I put a suspension lift on this truck. It is an OLD Kentrol body. with metal tailgate, grill, and dash. Professional paint and body work was done on it and was said to take alot to look like this. The problem the guy had with it was the rear wheel wells were differant sizes! The drivers side opening was smaller and to the rear more than the passengers so the rear tire would hit the fender. We put a complete new 4.5" suspension on it to give him more room for the 34" tires. It was odd but also a very old tub!
How many irons do you have in the fire right now? What will you be doing with this one? Mild wheeler? Any other plans as of yet?
Good call on running a metal grille. The ugly grille is the only thing I don't like about 'glass Broncos.
What did you think of the fiberglass windshield frame? I have one the PO gave me but have been unsure about using it. How did the glass and seals work? Seems bigger than the metal in those areas.
How much of a pain is it to get all the electrical systems grounded? I'm looking into doing fiberglass everything, except hood, grille. What did you guys do in the electrical wiring area?
Thanks,
I am looking at a fiberglass tub made several years ago, and the inside panel near the rear fender wheels is "glassed in" solid and you cannot access the bedside area where you bolt the top's sides onto.
It is glassed on the inside of the bed, and the area above the filler neck region. And of course, the fender is on the upper outside edge.
So, you can't reach under as you would on the stock tubs to hold the nuts onto the bolts.
I am wondering if anyone who has a fiberglass tub like this could tell me how you fixed the top's mounting system at the Bronco's bedside?
I just want to know how this is mounted before I purchase the tub.
Thanks,
Charles
Do you have to ground every bulb individually, or just in the harness as it splits to log. For example brake light socket .... did you ground each bulb socket?
Any shots of the engine compartment? Id like to get a better idea on the core support, inner fenders, etc. Really debating on a glass tub. Might be the way to go instead of replacing all the old steel. Sounds like everybody has been happy with theirs so far.
