Small Dent .. How would you fix this.
Pa PITT
Stephenville TEXAS
..OK So how would you guys fix this dent. . I am looking for a secton of the fender in the wanted section.
Not much response so I thought I'd ask here.
SO JUST how would you fix this dent..
It's good metal . Not rusty.. So do you heat & hammer it out. Or cut & replace ..
I've even thought of Cutting it about 2 inches above the Door latch loop.. Hammer that back into place . Then cut & splice the top Cosmetic section into place.
.. What would you do.& can I buy this piece of quarter .
Pa PITT
Pa PITT
Stephenville TEXAS
Well was supposed to be .
rydog1130
you might have to remove that striker post brace so you can get a hammer in there to work it back out, that's a "big" dent lol
suckerpunched
thats what I would do. If I couldn't get the lower quarter straight after removing the striker post I would cut part of the front edge off and make a patch.
Pa PITT
Pa PITT
Stephenville TEXAS
.. I've been gathering up parts to build this Bronco for 5 years. Or so!
I've been looking at this Dent since I've owned this Bronco. But somewhere along the line I began to get older. THIS WAS NOT PART OF MY PLAN.
THEN i WENT THROUGH a couple of Financial tough times. Job changes .. Farming Sucks .Stock Markets & Rent houses ..I'd always been able to rebuild my Box before .. But a heart attack & Getting old . I decided I might need to rethink some of the things I wanted to do.
..... I Have never got myself a lift for my shop. SO I'd decided to sell this Red Bronco. But I'D LOOKED AT THIS DENT ONE MORE TIME & I feel if I can fix this dent . I think I can help this Bronco sell faster & I do still enjoy fixing some things.
Crush
Greenbottom, WV
I would weld a plate to the edge of where the quarter meets the striker post about a 6"long piece. Get a good weld on it. then use a port a power or a winch from another vehicle to pull straight out on it while you tap the door post with a hammer to help straighten it out. applying heat to the striker post will also help make it pull easier. get some pull pressure on it and then heat and hammer. it looks solid enough to not pull apart.
once you get the door post in the shape it is supposed to be you can cut the welded bracket off and grind down the welded area. then you can work on the lower quarter by working from the inside and hammering it or using a dent puller from the outside. I would try this before cutting out the striker post
Pa PITT
Pa PITT
Stephenville TEXAS
Crush I like that thought. I feel it's strong enough Or Solid enough that if I can get enough heat to it .. It should pull out .. & I've felt all along that the Door post striker needs to stay in place. I don't have a porter power .. But do have tractors & Come a longs ... I May have to invest in some big RoseBuds..
Wonder if Harbor Freight sells rosebuds .
Rustytruck
If it was mine i would drill out the spot welds where the side panel meets the door jamb this will allow the 2 panels to move independently making them much easier to get back in place and straightend up. Get them mostly straight and weld them back up and then do the final body work.
Cortez
Pa - if that dent is “small” then I’m a Monkeys Uncle. Your killing me :eek:
rydog1130
.....how much for the bronco with the dent and how much after it's gone? :)
bronkenn
Bronco Guy
Southeast Ohio
This is how I would begin. Got to get the striker post squared up before you can fix the quarter. Ken
needsmoarturbo
I was looking at it, without a frame rack I would be using my porra power from harbor freight. Put it up inside the wheel well and use it with some blocks of wood to press it out from the inside if possible
Pa PITT
Pa PITT
Stephenville TEXAS
... Man lots of good advise. KEEP IT COMING..
I GET A CHUCKLE AT ME CALLING IT A SMALL DENT.
YES IT'S UGLY But It's out in the open & I can get to it from about all angles.
Much better than having a Front door post jammed in about 4 inches & Dash issues & Inner fender & Or frame work.
.. To Me his is just one you work on & tweak a little here & some there. Don't get to excited & NOT IN A HURRY.
Pa PITT
Pa PITT
Stephenville TEXAS
Rydog .. I was not planning to add much to the cost of this Bronco by fixing this dent.
I kind of plan on leaving it on a primer coat. But after my 40+ years of being around this business I figured If this dent is repaired. & a rookie buys it ..
He will have a much better shot at enjoying his Classic.
