msweb
- Aug 29, 2003
- 2,377
Just came home from a wonderful evening over at Tuff68's. WONDERFUL people and wow, BEAUTIFUL Bronco and another on the way (which hopefully will NOT be Pink Panther Pink!).
I was going to drive My Bronco over but discovered a leaking freeze plug. Went to move it into the garage for the night but she wouldn't start. Cranked up once but stalled, then seemed like a dead battery. I growl, put the charger on and head over to David and Rachel's place for a cookout that was awesome.
So I get home with a belly full of great food and want to put the Bronco in the garage. The battery is fully charged but still won't crank. Sounds like bad solenoid so I jump it across the terminals with a screwdriver (wonder how many times a day someone does that...). Every time I make contact I hear the click and the negative battery cable starts smokin!
My mother is there, she says yeah, did that last time you tried to start it (before leaving earlier - tried to jump it with the boost pack but no luck).
Drove around all over the place last night, had a great time w/o any problems. She ran good, never went over 190 and the next day has a leaking freeze plug and smoking hot battery cables???
Why won't she start (won't crank at all, just the dreaded "click")? Battery terminals are clean and tight and yes, I know, it's a crappy kind of terminal but it's always worked!
Smoke was coming from just behind the clamp holding the cable to the terminal. Any ideas what's up?
