gnpenning
Bronco Slave
Had good luck with both ways. Thought there might be more that have tried it. Tried the wax first. Tried the crayon when I couldn't find any wax. Kids didn't even miss them.
OK...all of you have provided excellent tips and techniques...a great resource CB is and all its members
Harbor Freight has a 90a Wire feed Welder...$100...write ups are decent and appears perfect for this little task and typical Bronco stuff minus heavy metal welding...
The addition of Lincoln .35 wire w/solder seems to be a great setup for it and here is my reasoning:
Timing Cover $65 JBG
Seal $5.00 JBG
Oil Pan Gasket $15.00 JBG
Propane Torch Set $65.00
Time...I have none to "F" around with this plus the worry of the timing cover bolts, though I just bought a new Cloyes Billet Timing Chain and Gears for it while it was open.
So, going the Wire Feed route I "technically" save a chunk of change and time "in theory" and I have a new play toy also
Bob-
Accessories? The only thing I am doing is putting an RJM 165a Alt in with their weatherpak and a new alternator bracket setup.
So today I decided to put in my 3G alternator that I have had sitting in its box for 6 months....the EB has AC so I needed to pull the double bracket as I have a new billet system to install also.
When you put this all back together put a thin coat of silicone on the threads and shanks of all thes bollts it will stop the bolts from coroading into the cover and act as antisieze on the bolts. Save alot of headaches later.
I use HighTac on the paper seals for the water pump and timing chain
then rtv on the bolts that go into water jackets
on the oil pan go for the one piece. It will be much easier and I have never had on leak.
