phillipmhampton
- Sep 5, 2012
- 24
just installed wiring harness after restoration of 74. having trouble with dash illum lights and gauges. gauges don't do anything. ivr reading variable voltage on back. fuse block has power to all fuses except dash lights 2 amp fuse. also have tried to different headlight switches in every position.
A. Are these independent issues?
B. voltage to gauges is <1 to 5 volts. shouldn't the gauges at least flutter? checked voltage by grounding to back of gauge/spedo housing so i think ground is good.
C. there is phantom blue and red wire to the back of ignition switch (post not plug). can't seem to find it on wiring diagrams. any ideas?
Thanks in advance for any answers!
