spacer between spindle and knuckle
broncobilly_69
Lebanon
I'm doing the chevy disk brake conversion and between the old spindle and the steering knucle there was a spacer that is tapered so that depending how I put it back on it will effect my toe in (caster/camber?) and my alignment. I did not see how it was on there originally and in both my Haynes and Chilton manual it is not even mentioned. Does anybody know if I need this spacer, and if I do which way it should be oriented?
broncnaz
that is for Camber unless you know what your camber was your kinda screwed you'll have to have a shop check it to see if you need it. If you have too much or too little camber the inside or outside edge of that tire will wear quickly.
scsm76
Shaver Lake, CA
Most early broncos had the camber pointing out like this \---/ put the shims in so that the widest part is at the bottom and it should be right. I added them to mine to make the wheels straight up and down.
scsm76
Shaver Lake, CA
after you have it back together you can check your camber by parking it on a level service and put a square on the floor up against your tire and measure the distance to the top of the rim and to the bottom of the rim from the square. This should give you a good idea of whether it is leaning in or out.
72Sport
Thick side goes down. Going from bias ply tires (from factory) you need to decrease camber when running radials. The spacers or shims will reduce or eliminate the outside edge tread wear.
broncobilly_69
broncobilly_69
Lebanon
Thanks-a-million guys. I didn't want to pay a shop to pull the spindles off again and turn the spacer to get the right camber. I think I'll still take it in for an alignment though just to be on the safe side. Tires cost too much to wear out due to improper alignment.
