Spark plugs after EFI conversion
bronccar
Going to be running 93 mustang efi on a 73 302.
Which plugs should I use? Something spec'd for the mustang?
Thanks!
bronccar
bronccar
Nevermind, I guess it has to be for the bronco heads (reach is different)
B RON CO
Statesville, NC
Hi, when you go with electronic ignition you can open up the spark plug gaps to probably .045 if you haven't already. Good luck
73azbronco
Actually you need the plug for the ignition you are using, old points are a tighter gap, TFI/electronic ignition opened to about .043-45.
