Speakers
Acknud
Morganfield, Ky
My radio and speakers died so I took them out. I doubt I will put one back in. I am going to just use Spotify on my phone. With all the wind and engine noise I can't hear it. I run with the lid off all summer. I was thinking about getting a bluetooth speaker or system to use. It will need to be pretty rugged and loud. Any suggestions?
bronconut73
I am amazed at how loud and clear my daughters Blue tooth cube speaker is.
Her and her friends put the cube on the back porch and play out in the pool and hear it perfectly well. It actually has good bass. It is also very directional. Aim it away from who doesn't want to hear it and the sound is diminished considerably.
74BroncoCO
You could look into a bluetooth amp for an auto. Something that will accept a signal from a device and then push the power to some speakers. Marine grade would be a good idea.
I want to do this as well, but my poor old radio is still working. But I've never been happy with the sound of my system.
kip60
BC Broncos has a pod that covers the wiper motor and gearing. It has speakers that can be installed and I think it has an option for just an ipod also. You could put bluetooth speakers in also.
JaxLax
Jacksonville, FL
Nice deal on that one.. would have to find a way to waterproof it probably
$180 for a 2 channel bluetooth amp? :eek::eek::eek:
You should be able to find a marine head unit with rear enclosure, front panel cover, and 4 marine speakers for that kind of cash.
UGH
FINE
Using Crutchfield as above (even though you can ALWAYS find it cheaper elsewhere)
Here's a Marine CD receiver with BT and a pair of speakers from Kenwood
Or another CD receiver with BT and FOUR speakers from Boss
bend some flat sheet metal for an underside splash guard or get a plastic cereal container to cover the rear and snag a $10 flip down face shield.
And you can find a thousand (literally) $30-50 BT amps out there if that's all you want and you want it hidden.
Just depends on how hidden, powerful, and stock you want everything to look.
sprdv1
REBEL
thanks man ..... :) (lazy this morning)
UGH
FINE
sk1nw4lk3r
I have one of these,
Hanging in my family cage, downfiring, in between the driver and passenger seats.
From the side, you can't even see it. It is LOUD. Sounds great! Bluetooth, you can control everything from the unit itself.
Ordered it from MTX, and requested two extra clamps for it so I could hang it this way. Had to modify the clamps a little bit, but it works REALLY well. I'm super happy with it.
77BRONKOTN
I just hang my Ryobi (Blueteeth) radio from the bar. Uses the same huge battery as the fan I hang from the bar and uses the same battery as the absolutely worthless Ryobi tire inflator %)
74BroncoCO
That's nice! I see it runs $379 on MTX. But I do like the soundbar idea so you don't have a huge pod speaker taking up valuable head space.
sk1nw4lk3r
Make sure you get the MUD6SPBT
BT means bluetooth! I think it's $399 for the bluetooth version.
Also, it's waterproof!
74BroncoCO
I'm looking on the used market. But I'm not plugged into the marine or UTV crowd. That's just too much for my blood currently.
JefeAZ
Tucson
Torn between a bluetooth sound bar on the cage or a marine bluetooth amp under the seat and 2 rear speakers in the quarter panels. Don't want a stereo in the dash and Ive never HAD to have music on my short drives. The amp/speaker route would be cheaper and a whole lot easier install
JefeAZ
Tucson
Ya I guess it wouldn't be that much easier as both need power ran to the battery. I don't want visible wires so Id have to cut holes into the cage
sk1nw4lk3r
When I pull the cage to paint it, I will drill a couple small holes and run it through there.
Previous owner put a CD player in the Tuffy Console. I just took the power wire to that, and hooked it up to the soundbar. Including some minor custom brackets, I have maybe 2 total hours into the install.
