Speedo cable with VSS and NP205
WorkerBee
Northern CA
Does anyone have the correct part # speedometer cable that'll fit a factory Ford VSS from an F150? I have the stock gauge cluster with the standard threaded fitting on the other end. I have the VSS but need the speedometer cable. I'd rather not buy the kit if I don't have to. I can't seem to find the correct cable that goes into the VSS with that threaded fitting on the other end. Thanks!
