speedo gear in T-case
getfuzzy
I'm back on the road but my new speedo is not working. I pulled the speedo drive out of the T-case[VSS] to make sure that the gear was OK and that the drive gear in the T-case was OK too. Now heres the question I put my big deget in the hole to check the drive gear and it turns free the gear that is. I checked the service manuel and its not to clear but I would think the gear should not turn free like that. Before I tare into it I though I ask.
Viperwolf1
electron whisperer
If it's the plastic gear they can break loose and spin. Find another one with the same number of teeth.
getfuzzy
getfuzzy
Viper are you talking about the gear on the output shaft or on the VSS. I'll start the tare down after work .
Viperwolf1
electron whisperer
The gear on the output shaft. It has a steel sleeve that it's supposed to be bonded to but I've seen a few that have separated.
getfuzzy
getfuzzy
Just to let evey one know it wasn't the gear. I guess when you have fresh gear lub on your finger and a 40 year old gear thats as smooth as a babys butt you think its turning. Also the gear was solid steel. I wound up tracing it down to a bad ground on the VSS to my Autometer elc speedo.
